Advanced filters how to?????
bobmac1547
Been thanked: 12 times
Post by bobmac1547 »
In the calendar module, I need to find all records created or modified after a specific date. I do this report weekly.
Unfortunately, even in adanced search, EPIM only allows me to filter in very gross ways, like, in my case, 2024 and/or 2025. I really need it to filter down to the specific date.
Is there a way to do this?
If not, I'd like to make the suggestion here and now...
Thanks...
M&M
Has thanked: 10 times
Re: Advanced filters how to?????
Post by M&M »
Hello bobmac1547,
you can actually evaluate the data records very well using filters.
There are different filter options, which can also be combined.
The column filter can be opened via the “triangle in the square” and you can filter the data by years, months or days. If necessary, you can also filter several columns at the same time.
Example of filter options for the “Start Time” column
Right-click on a column title to display a selection of columns.
If there is no filter button in your toolbar, right-click on the toolbar and select “Customize the toolbar ...”
Good luck M&M
