Max line length exceeded.
Steve Shank
Has thanked: 32 times
Been thanked: 21 times
Post by Steve Shank »
Doing the archiver, version 12.1
Archived tasks and calendar fine.
When I tried to archive emails < 1/01/23 I get the Max line length exceeded error.
I'm guessing some email's subject is too long. My file paths are not excessive.
It works for a while and creates an archive of 17 MB. Then gives the error.
I've optimized the database.
Is there a way to find the offending email? It seems to be in 2022
Steve Shank
Re: Max line length exceeded.
Solved it!
Nearly all the emails I wished to remove were in a folder (2022). I created a new folder, outside of Archive called 2022b. Then cut and pasted all the emails from the old folder to the new one and deleted the old folder. Then the program locked up and I ended it. Then used the Archiver again to archive emails before 1/1/23 and it completed the job just fine and deleted the old emails.
