[SOLVED] [Tasks] How to move Notes to the right-hand side?
littlebigman
Been thanked: 5 times
Post by littlebigman »
After an update broke my computer (grrr), I had to reinstall EPIM on a new Windows computer.
In the Tasks section, I can't find how to have the Notes section vertically in the right-hand side like I used to have.
There's nothing obvious in the relevant section in Tools > Options > Modules > Tasks, and drag 'n drop doesn't do it either.
Thank you.
Edit: Found it. It's in View > Layout > Vertical View
