Cant Just Quick Change single digit in time/date by mouse.
AJ
Has thanked: 48 times
Been thanked: 7 times
Post by AJ »
hi admin,
i try to quick efficient and intuitive select one digit in date/time by third click, no reaction.
its most annoing in time, must go smt like flash.
third click and up/down by one of these ... left/right click and/or wheel for/back.
seem sadly still not work.
thx
Helps Make EPIM Great/No1!
Has thanked: 1616 times
Been thanked: 1133 times
Re: Cant Just Quick Change single digit in time/date by mouse.
Could you please share a screenshot or provide more specific details about where exactly you're trying to change date/time?
AJ
Post by AJ »
admin wrote: Tue Apr 01, 2025 9:30 am Could you please share a screenshot or provide more specific details about where exactly you're trying to change date/time?
in a task or appt, dates, time and reminder, there is no 3x click for one digit select, like
1click time/date select
2click 2digit select
3click only one digit selected.
i hope you know now.
AJ
Post by AJ »
hi admin,
correction.
the 3click in time sections, in date it would be 2click, as it marks only 2digit by 1click and not the whole date, like in time.
i think its standard behaviour in any date and time in epim, also reminder. so begin, end and reminder.
AJ
Post by AJ »
hi admin,
do you understand now?
we had a chat about the multiclick for marking text, i think you can now understand the multiclick.
there is a difference between time and date, like i noticed, explained in last post.
Unfortunately, we’re still having difficulty understanding your idea. As mentioned earlier, a screenshot would be helpful.
AJ
Post by AJ »
admin wrote: Fri Apr 04, 2025 9:37 am Unfortunately, we’re still having difficulty understanding your idea. As mentioned earlier, a screenshot would be helpful.
its very simple, like said above, the 3rd or 2nd click, depending if time or date should mark only one digit.
you need change 00 to 20 minutes, just click quick one more time then now and select the first 0 for change.
you can only select two digits in time and date, we had earlier such problems for marking text or so.
for that you have also multiple click to choose from letter, word till whole area.
just try how many clicks you need to choose single digit in time or date!
not possible, as 2nd or 3rd click not coded, to do so. in text you fixed it, was same thing.
will see if i find how one user explained it, you got it then.
i mean if you go first time in time or date area, you can choose smaller area by clicking multiple times, choosed area gets smaller, you just have to know it. just try intuitively to click in more times and observe the reaction.
as i read back, for marking text you need first position the cursor with first click.
for the numbers in time and date, in appt and tasks, i need to choose only the one digit under the cursor, if click 2 or 3 times. now you can only switch max to two digit select by multiple click.
now you got it.
AJ
Post by AJ »
hi admin,
this is the other quick fix for minor version.
its like the former text selecting issue, by multiple click.
i can try to find the explanation, but i think i can explain clear...
pls go to time or date in any appt and quick click two or three times in the field, on a number in date or time.
you will see that you cant select only one digit by clicking one more time in it.
you have to quick fast as to generate a double or triple click selecting only one digit.
thx
Unfortunately, we cannot provide an ETA for implementing this feature. We also cannot guarantee its implementation at this time. However, anything is possible and this could change in the future.
AJ
Post by AJ »
ok, hope it comes sometime as could change 00 to 20 by multiclick and '2'.
its high effizient.
as i remember the mouse wheel doesnt work to change the numbers, instead only scrolling down, but other way round would be better, as only one line of settings out of sight and in other, main settings see all at once.
however, hoped the multiclick could be working same way as by text.
this would be maybe better than changing it by scrolling.
but maybe you find changing time and date by scrolling better.
i think i saw it working in some place.
thx
