show next appt with countdown in all modules in top toolbar!
hi admin,
let show next appt with or without countdown, before time, in all modules in top toolbar, by default or added element!
it would improve to stop trying to do other things to long before next scheduled (important) appt or task.
its great to focus and come down before next task or appt.
you could easy check in toolbar, most focus area, how long, if activated countdown before the time of next appt or task as appt.
it would great improve stressless and focused on next/important things.
it comes in my top ten, as i get sometime to do two or three things at time, and could so better note things for later instead of getting mad.
and IMPORTANT, one should see if reminder setted, as bell, and you could set reminder by clicking the bell, by popup with times under it.
it would make you get easy weekend if you see the next appt quick, dont forget it, and see if rem setted and could quick adjust or reschedule if needed.
i try to get the most of the top toolbar and possibly get rid of menu and statusbar, as clean, modern and used since 10 or 20 years in other tools, and still hard missing here.
thx!
thx!
Helps Make EPIM Great/No1!
- Has thanked: 1639 times
- Been thanked: 1160 times
Re: show next appt with countdown in all modules in toolbar!
Noted, thank you.
hi admin,
as you answered, i improved the one sentence or so post.
pls take a 2nd look to add notes in your note.
i described needed function and remembered to add icons for some kee/key functions.
thx!
