autocomplete
uzzer
autocomplete
Post by uzzer »
I use a field "Event of Acquaintance" for my contacts. It is to help me remind myself how I met a contact. Often a lot of my contacts are associated with the same event of acquaintance - e.g. the classmates. Then I have to type it over and over again. Does EssentialPIM have an option like autocomplete or sth like that so I do not type the same thing many times?
You can copy contact and paste it in the main view- i.e you can clone contacts which have fields pre- filled.
uzzer
Re: autocomplete
Post by uzzer »
Certainly, but autocomplete would be faster.
ypim
Has thanked: 18 times
Been thanked: 8 times
Re: autocomplete
Post by ypim »
And which fields should be used for autocomplete? I mean which fields should store that data?
One for each?
keiooz
Re: autocomplete
Post by keiooz »
This should be an additional feature where you can extract automatically instead of simply copying and pasting.
Works like a charm!! Image
