No edit cursor when adding/editing contacts
When adding or editing a contact in v1.5.1, there is no edit cursor in the edited field.
The insertion point does change to the position clicked, but no cursor is displayed.
When you add a new contact, the pane (a part of which is attached) appears. Now
1. Enter a first name (I entered "abcdefg")
2. Position the cursor anywhere within the strng (I positioned it between d and e), and click there once.
No edit cursor (vertical bar) is visible at the cursor position, although I coud insert "---" where I wanted to.
Just a cosmetic bug.
- nocursor.png (5.79 KiB) Viewed 4246 times
