Toolbar
MEgler
Been thanked: 4 times
Toolbar
Post by MEgler »
I think that now EPIM has so many functions that configurable toolbar with icons will be very nice ex6tension and will make EPIM much more easier to use.
Re: Toolbar
Thanks, so far no such plans.
ivg
Re: Toolbar
Post by ivg »
I would highly support this as its quite rudimentary not to have a configurable toolbar nowdays (ecpecially if EPIM competes with outlook - which already offers dinamic toolbars - which i don't vote for - a simple customisable one would perfectly do)
Also with a great addition of styles - people who swithed to styles still have half of the toolbar occupied with useless controls for font type and size selection
I understand that development of a customisable toolbar feature does require a lot of time and may not fit well in you current development plan but - as a quick workaround I suggest to insert toolbar buttons keys into EPIM.ini file so that a user could disable not used buttons and you would save time creating dialogs and logic for the toolbar customisations at this stage..
ps Here I talk about a notes toolbar which is a most control dense toolbar and needs that flexibility
