using planner and contacts
hello,
is it possible to make appointments in the planner/calender by clicking ppl in my contact list. and if that is possible how do i have to do that. i use essentialpim pro the latest version
best regards
remco (the netherlands
0
best regards
0
Re: using planner and contacts
No currently this is not possible. What would like EPIM to do when you create a task by clicking on some contact in EPIM?
This is something I was thinking would be great. The possibility to right click on a contact and have the following options:
1) 'send message' - have EPIM pop up a new mail message with the contact's address in the To field
2) create To Do - open a new To Do (which could now easily appear in schedule at specific date/time if desired) so you can say "Call John" or "Ask John about such and such". It would be ideal if "John's" contact information (even selecting which fields you need?) then was either embedded in the To Do (perhaps copied into the Notes section) or if there was a link that you could click on from in the To Do that would automatically open your contact's information.
Thank you. Both suggestions are excellent. We will try to implement them, but of course depends on schedule...
