how to combine the Notes in A.epim into B.epim
pandeng
Post by pandeng »
how to combine the Notes in A.epim into B.epim?
lost some tasks when change to 3.2RC1,so I need to go back to the backup file B.epim.
while many notes change in the A.epim,now I want to combine the Notes in A.epim into B.epim?
Re: how to combine the Notes in A.epim into B.epim
actually no Task should be lost. Today we made a silent update fixing problem with showing them. So if you redownload, you should see all Tasks.
You can combine Notes if you use EPIM Sync (you can turn off synchronization of all other modules if you do not need to combine data in them). Trial of EPIM Sync includes 2 full synchronizations, let me know if you need more.
