EssentialPIM 3.5 Release Candidate 1
Hi everyone,
today we are releasing 3.5 with several major and many minor new features. This is a Public Release Candidate 1.
Downloads:
EssentialPIM Free Desktop: http://www.essentialpim.com/download/be ... lPIM35.exe
EssentialPIM Pro Desktop: http://www.essentialpim.com/download/be ... MPro35.exe
EssentialPIM Pro Portable: http://www.essentialpim.com/download/be ... Port35.zip
New Features:
- Global cross linking (make link to other item from anywhere)*
- Rich text formatting in Schedule and other items*
- Google Contacts Synchronization*
- Spell checking in Mail
- Importing Outlook mail
- Google Apps now supported (Calendar and Contacts)*
- 2-week view in Schedule
- Search and Replace dialog in Notes
- Possibility to insert Horizontal Line in Notes
- Total time display for ToDos (bottom line)
- New system for reminders in ToDo module
- Days are highlighted in a small calendar
- EPIM now shows in which versions database was opened (in Database Management)
- Automatic checking for new versions
*- in Pro version only
Nomade
Re: EssentialPIM 3.5 Release Candidate 1
Post by Nomade »
Hi Max,
What a nice job. No problem whatsoever opening database with this release and finaly, contacts in alphabetic order when clicking on TO: when sending new e-mail. For all the other improvements, what can I say, there just GREAT. This is one of the best investment I ever made. :wink:
Regards
a8907433
Been thanked: 183 times
Post by a8907433 »
Hi Max,
I´m trying EPIM 3.5- no errors until now! :D It seems to be more stable than the previous version.
1) Some remarks: after opening the database with 3.5 it can´t be opened with 3.23 anymore.
2) In "search and replace" the text (name) or icons on the tab is missing
When this version proves stability for longer time, then this will replace my current PIM and mail solution!
epim tab.jpg (15.24 KiB) Viewed 17497 times
a8907433 wrote: 1) Some remarks: after opening the database with 3.5 it can´t be opened with 3.23 anymore.
1- this will always be so. We upgrade database to add new features and previous version does not understand it
2- UPDATE. Looks like you did not renew the language file.
@ndreas
Been thanked: 4 times
Post by @ndreas »
Hi Max,
Link from your mail doesn't work!
Best regards
Andreas
Win 10 Pro x64 - EPim Pro 9.x - Lifetime subscription to EssentialPIM upgrades
bhoyt
Post by bhoyt »
Just got the email notification. The links are broken.
Thanks! Resent the message.
veganchris
Post by veganchris »
does epimsync work with the new database?
bhoyt
Post by bhoyt »
Links are still broken. This is what I received.
Downloads:
lPIM35.exe
MPro35.exe
Port35.zip
identity76
Post by identity76 »
Max wrote:EssentialPIM Pro Portable: http://www.essentialpim.com/download/be ... Port35.zip
are you also going to release a u3 version?
Not yet. When we release RC2 or final version, EPIM Sync will work with it.
Yes, with next build (RC2 or final release)
xman_by
Post by xman_by »
Thank you for the new version! I've just almost decided to buy it :)
Some notes:
1. I was a bit disapointed having found out that there's no possibility to set multiple tags (colors) to tasks/notes. I hope it will be soon. If it's difficult to realize quickly you could add an advanced search which allows AND and OR operations (thus we'll be able to point out what about our note or task is and use search instead of filtering: for instance, I can title my task as 'Phone John [tags: business, project1, phone]' and use search phrase like 'business AND phone' in order to see this task in results).
2. I tried you program at my friend's pc and it showed me an error when I was trying to save/open my database. It was saying that I have some debugger on my computer :(
3. It would be nice to see a DATE field for notes and a possibility to sort out a notes list as well as tasks list.
4. Emails gouped by topic/sender - still looking forward to :)
nkbb
Post by nkbb »
when i open the 3.23 data, some records were lost!!
nkbb wrote:when i open the 3.23 data, some records were lost!!
For example? In any case (but I do not think that's the case)- EPIM 3.5 makes a backup of your 3.2 database, so you will always get your data in 3.23
