EPIM Pro 12 - Sync with Outlook 64 bits ?
- Laurent C.
- Has thanked: 5 times
- Been thanked: 14 times
Hi
Since 2020 — now in 2025 — does EssentialPIM 12.1.4 release and later syncs directly with Outlook 2029/2021 64 bits versions ?
It's difficult — near impossible to find an answer on https://www.essentialpim.com/blog-and-news ...
Regards
Regards
EPIM Pro + EPIMA Pro (Android) / W10 Pro 64 bits FR + Office 2019 Pro Plus / Pixel 7 Pro
- DanFelix
- Has thanked: 82 times
- Been thanked: 8 times
Re: EPIM Pro 12 - Sync with Outlook 64 bits ?
Outlook has changed. What used to be a desktop version has been migrated to a cloud version. Are you using an installed version of Outlook? Can you still access your account at outlook.com? I use EPIM without issue on a 64bit Win 11 system but I stopped syncing with the MS Outlook account because of changes MS has made to Outlook.
- Laurent C.
Hi
I use a desktop Outlook LTSC and do not want to go to cloud
The sync works with desktop Outlook
The subject here is : does MAPI 64 bits is now supporters by EPIM
Rgds
Rgds
- DanFelix
Understood. But, MS is planning to deprecate desktop Outlook. The MAPI issue is overtaken by bigger events. For more info:
https://www.howtogeek.com/microsoft-pla ... r-windows/
- Been thanked: 1135 times
Here's the special app that's able to sync with 64-bit versions of Outlook:
https://www.essentialpim.com/features/f ... tlook-sync
- Laurent C.
Hi
I know EPIM-Outlook Sync, but I do not need to sync two PST files manually
I need the capacity of EPIM Pro to sync Android to Outlook 64 bits automatically...
Regards
Regards
Currently, this functionality isn't available directly in EPIM and can only be achieved through the EPIM-Outlook Sync app.
- Laurent C.
Thank you admin — clear
I guess this ticket is closed now...
Regards
Regards
- Laurent C.
Yes, closed
